need help
few questions, issues:
1. the ads are not showing on the home page and not showing properly on post pages
2. where do i change what account or what is assigned to like button on posts, i want it to be assigned for the group, not for individual posts
3. where can i find short codes for Facebook like and share buttons, i want o make them big!
4. i have another content site that i have a widget for, can u help me to where to enter the code? these are the instructions i have:
Place this code in the <head> section: —-> where or which line can i place that
and Place this code where you want the “Below Article Thumbnails” widget to render: —> where do i put this, i want this to show up on every page below my content, including the home page
Place this code at the end of your <body> tag: –> and where would i put htis
thank you, really appreciate the help!
My website is: just-yoga-it.com
1. Usually it takes a few days until google scans your site and delivers ad content for you, the code seems to be – http://screencast.com/t/cy8X1Uu4ure , you just have to wait.
2. There’s no account options on share, the article is simply shared by each visitor on his account/page.
3. The size can be changed from CSS, use the browser inspector to find the current parameters and modify them using custom css – http://screencast.com/t/0loyEnLMz
4. Add the head code here – http://screencast.com/t/pxLi5kaQmm
For the content you have to edit all templates (pages or posts) where you want to display that widget – http://screencast.com/t/LuXAe8eBku7X – http://screencast.com/t/jm9pUVD2c8a
The body end can be found here – http://screencast.com/t/p8nCSR5gxi
Thank you, Emil G.
there is no way to insert the code somewehere and it will automatically render on every post?
for the adsense ads, its been more then few days and they are still not showing up. something is wrong in the template, can u pls take a look!, thank you
None of the adsence showing up on the home page and not on the mobile. Its not bec of adsense code.something is wront with the template. please help me fix it…
> It will appear on every post, but the theme comes with multiple styles for posts. If you don’t change it you could edit only the loop-single.php and ignore the rest.
> Please send an email at contact@tagdiv.com , paste a link to this conversation and provide wp-admin access so i can take a look.
