need help
how i can delete this hot new and some staf like in picture
https://prnt.sc/l13kdd
Hello rida,
You can try using the code below and place it in Theme panel -> Custom CSS area.
.block-title{
display:none;
Also, for a more accurate code, you should provide your website URL so I can take a closer look at this section.
Hello rida,
I have checked your website and I did not saw the block title -> https://www.screencast.com/t/JbUCIpPxviKj The code which I gave you seems to work as expected. Where is the problem? Clear all of the caches and check again the results.
it didn’t hide it’s still showed i want to hide it
Hello Rida,
Where is your block titles? I have inspected again your website but I did not saw them. Provide some screens with the problem because on my end, I see this -> https://www.screencast.com/t/aoBkIgddXbM
