Hi, I want to make a block like this one, (http://prntscr.com/bj2szy) in my site http://www.planetbomb.net/
Please me in details.
Those blocks are custom made and our theme does not provide them. You can try out the different block layouts our theme provides here: http://demo.tagdiv.com/newspaper/block-1/
The second one is more complicated to make, but the first example you showed can be achieved by using block 15
I hope this helps.
Thanks for the help, you guys are always so helpful. however, I have another issue with “smart list 1”.
when I create a post using style 5 with smart list 1, its comes like (http://prntscr.com/bj5l4i) after clicking the next button then show me the full image.
Waiting for a solution.
Smart lists are very sensitive to html tags that are not closed properly. Pleas use only standard html inside a smart list and make sure you close all tags in text mode. It’s a good idea to re-create it from scratch when this situation arises as it takes too long to find the one tag that is not closed properly. Simply copy the text over in a new post and add your images. Then set your titles and check the smart-list again.
If you still have problems with smartlists, try to also disable all plugins except visual composer, clear cache and reset cdn files in order to rule out a plugin conflict.
Let us know how it goes.
That means you have a plugin conflict. In this case you must disable all plugins except visual composer again and then re-activate the plugins one by one and test your smrtlist after each one you activate so you can figure out which one causes the issue. When you identify the one that conflicts, you must remove/replace it with another that does not create problems. Unfortunately not all plugins are compatible with premium themes.
Hello tintin,
Please try to contact your hosting provider and ask them to clear all the server caches and test it again. So, if your problem is still there after this, please provide the link with that smart list so I can identify the problem.
Hope this helps!
Hello tintin,
If you want to add an ad to the bottom of your smart list 5, you will have to use a bit of code and add this in td_smart_list_5.php in order to achieve as you wish. Please follow the steps, like this -> http://screencast.com/t/BcraJMrzP8QY The code which you will need is below ->
$buffy .= do_shortcode('[td_block_ad_box spot_id="custom_ad_1"]'); Please ensure that you have added your desired ad code in Custom Ad 1 from your panel, like this -> http://screencast.com/t/Nb4tQKkFr8D and the result you should see here -> http://screencast.com/t/Zh2tB3lHL
Hope this helps!
If is not what you mean, please provide more details.
