Need help adding Javascript
I’m trying to add an animation effect when clicking an anchor link, so that the page does not jump to that section. I’m using the following under Custom Code > Javascript in the theme panel.
src="https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js";
// Bind all a href clicks to this function
        $(document).on('click', 'a', function(event){
            // Prevent default events
            event.preventDefault();
            // Animate the body (html page) to scroll to the referring element
            $('html, body').animate({
                scrollTop: $( $.attr(this, 'href') ).offset().top
            }, 1000);
I followed instructions to not include the script tags but it does not seem to be working. Here is the page I’m trying to get it to function on: https://mp.adcreview.com/privacy-statement/ – the links to anchors are in the right rail.
  • This topic was modified 7 years by smehr1.
Did you try to set the code like this -> http://prntscr.com/pnwg8a and this was not working, if is so, then, please set the code like this -> http://prntscr.com/pnwh5p -> http://prntscr.com/pnwhce
Hope this will help you!
Thank you Calin!
