Need help for Article bottom ads code
I have looking code for article bottom ads, where is it code put in the php file ?
I have want to modify or move this ads position to some where like bottom the comment box
or other place.
Thank you for help.
ZoLKoRn
  • This topic was modified 11 years by ZoLKoRn.
Want to move it like this picture for easy to understand, so where the code I should edit should be looking for
First you need to remove the article bottom add from post content like here: http://screencast.com/t/PWgzx852 After that you can use the do_shortcode(' ') function and insert the ad shortcode from VC: http://screencast.com/t/W4SFKPnoShnhttp://screencast.com/t/lqaJxdVdMee at page bottom in post template files corresponding for the post templates used: http://screencast.com/t/NujhBJ9CBhttp://screencast.com/t/7dYEalH9
Let me know how it goes and provide more details if you still need assistance on this.
Hi Andrei L.
Perfect ! everything work well.
http://www.zolkorn.com/news/asus-maximus-viii-extreme-motherboard-picture/
Thank you so much for your tutorial it easy to understanding and nice support 😉
Glad I could help!
