Need help in optimizing or finding the issue
Need help in optimizing or finding the issue. the script is taking 5 seconds to load. How do i fix this
Screenshort : https://www.screencast.com/t/UtbC6bv3
Please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Then please make sure the system status parameters are properly set: https://forum.tagdiv.com/system-status-parameters-guide/
Also test this on a wp default theme to see if the issue is present only when using our theme.
