I’m trying to modify the site’s structured data from “Person” to “Organization”. I’m unable to locate where the file or the code responsible for this structured data is located within the theme. Could you please point me to the file and the exact line of code where these JSON-LD structured data are defined?
Best regards.
Hi maryano, the best solution for this is to use a dedicate plugin for SEO and disable the one from the theme – https://i.imgur.com/UMr2mlX.png
thanks for the suggestion regarding the use of a dedicated SEO plugin. I agree that Yoast SEO is an excellent solution, however, in my case, I am using RankMath. Unfortunately, RankMath does not allow me to modify certain data structures that I am looking to optimize.
I have already disabled the article schema option of the theme and tried other plugins, but the problem persists. I feel more comfortable working directly with the code, I just need to know where to find it.
Hi maryano, I understand. To edit the theme files you’ll need to go to wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php then on line 782 – https://i.imgur.com/9V8XTTs.png and 813 – https://i.imgur.com/I3is71r.png
I hope this will help you!
