Need help locating to change stuff on hompage.
My website. http://www.asiaworldmedia.com/main/
Ok, I wanted to know where the menu are so I can make changes to the category on the homepage. Under category FASHION WEEK, GADGET WORLD, & BEST Smartphones.
Second, where can I locate the widget of the side menu under POPULAR VIDEO, HOLIDAY RECIPES?
Third, where can I locate the widget on the footer where EVEN MORE NEWS & POPULAR CATEGORY?
Thanks in advance!
You can edit the posts displayed in this block: http://screencast.com/t/lsnK4QM1kROv from Visual Composer pagebuilder: http://screencast.com/t/wr9hXXZ5yZ For more details about how can you customize the homepage please check this tutorial: https://forum.tagdiv.com/newsmag-homepage-how-to-build-and-set-it/
The indicated widgets are actually blocks from Visual Composer: http://screencast.com/t/tiZgngyzhgxP
This: http://screencast.com/t/pRKcTS96m is a block 7 and can be found in footer 2 widget: http://screencast.com/t/o9tQI3yLLE
If this is not what you mean please provide more details.
Thanks, everything work except that footer 2 widget. There’s nothing in that widget.
Hello tagdiv1000,
Please try to consult our documentation here -> https://forum.tagdiv.com/newsmag-footer-templates-2/ regarding on our footer templates. Please notice that the Footer 2 section work only in few cases and for some footer templates.
