Loaded the basic demo and it only shows text for my logo, even though I uploaded logos & favicons in the settings. Also it’s not showing the demo theme or anything after the Header medu and when I click on the green edit with TagDiv button I get a red error on the right saying “Error at rows: 2(models) : 1(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)”
Then I tried to load a template and it hangs on install
I’m missing something here.
hookedmagazine.ca is the website I’m trying to move over.
If you moved from one theme to anothere is possible that teh theme you had to use a builder that has its own shortcodes, so moving to a different theme, all taht have been made with the old theme builder will no longer work on the new theme and will be need to be rebuilt or to use a pre-build webiste.
“Error at rows: 2(models) : 1(dom). The model does not match the content … “: Most of the time, the problem is from a shortcode that is not compatible with our theme; therefore, after you set it with tagDiv Composer and save the page, the next time you try to edit it, you’ll get that error. The simplest and fastest way to resolve it is to use a page/template revision – https://wordpress.com/support/page-post-revisions/ (in this case will be a post template revision).
I hope this will help you!
