Need Help on Customization
Works fine. Thanks.
I will like to extend post area and reduce distance to the left and right sidebar. Look here ==> http://prntscr.com/ct4ifu
Hello hadharm,
Unfortunately, this is the default width of the theme if you are using the sidebar. Please notice that if you want to make your main container being wider, also you will have to change the width of the theme and please notice that our product does not have such an option for dynamic width and we do not recommend to do that through the custom CSS code because the layout of the theme will be damaged. If you want to change the width of the theme to be in full-width mode, please notice that is not a simple task and you will have to adjust the entire theme to the new width for better results.
If you want to display more levels in our theme and you are not aware of the steps in this regard, please consider hiring a freelancer/developer to do this for you because we cannot provide customization services at the moment, sorry!
okay thanks for the tips
Trying to add two script in custom javascript code fields. I see a message that do not include script tags
<script type="text/javascript" src="//pl13044261.puserving.com/03/6f/2d/036f2d455664fa983aafe50e0b8735db.js"></script>
<script type="text/javascript" src="//go.onclasrv.com/apu.php?zoneid=442386"></script>
I tried removing the tags but I still receive error ; missing and if the tags are there I use to see expected an identifier instead saw <
Pls help me rewrite the code as it should be placed in the custom field. Thanks.
Hello hadharm,
If you want to add a Javascript code, please notice that from Theme panel, you can add only one code. For example, for your first code, you should load this in Custom Code, like this -> http://screencast.com/t/VGkQyVknOK and if you have more than one code, others you must load them into header.php and footer.php.
Viewing 5 posts - 26 through 30 (of 30 total)
