Need help on Reducing Website Width
Hey I am currently using UrbanObserver theme, the theme looks good. Only the problem is the website width is very huge, I want to reduce the homepage width and single post section width, How to reduce that. Even header, footer, all the should be the same width, KIndly assist me
https://www.southmoviez.com/ Here is my website, What I am feeling is website with large width can be difficult for the users to read the content.
You need to stretch the row and set a different layout for it -> https://i.imgur.com/bqqhri3.jpeg -> https://tagdiv.com/flexibility-rows-columns-newspaper-theme/
-> https://tagdiv.com/how-to-add-delete-and-duplicate-row-newspaper-theme/
Also, you can set different width for columns.
I am unable to see the screenshot, I can adjust the size for homepage but what about the single post, how do I change the width
You need to edit and set the stretch row to the default.
Yea i got But i have changed for header, The question is how to set the default with for single post section. WHere I can make the changes? https://www.southmoviez.com/tamil/tamil-movie-news/iifa-utsavam-awards-2024/
How to adjust the width, Where I can make the changes
You need to do the same steps for the rows, where is the single post content https://i.imgur.com/zOC7Jvp.png
