Need help regarding Automatically smarter ads for AMP
I need help regarding inserting the Automatically smarter ads for AMP.
1. According to the instructions from the Google Adsense (Step 1: Turn on text & display ad formats), I turned it on. In the step two, they said to do “Copy and paste this script in the head tag of your AMP HTML”. Where should I paste it? Did not find any place to put the code in the Mobile Theme under Theme Panel.
2. In the third step, Google Adsense instructs that “Copy and paste this ad code in the body of your AMP HTML”. I put the ad in the “AdSense Auto Ads for AMP”. Is that correct?
3. What are the differences between Mobile Ads and AMP Ads? Should I use both or only AMP Ads?
Please help. Thanks in advance.
1. Please check our documentation for How to Make an AMP Ready Website with Newspaper Theme -> https://tagdiv.com/amp-newspaper-theme/ here you’ll find how and were to set the code ads.
2. Is no need to set the code in other parts, set them only in Amp Ads and the theme will do the rest for you.
3. There are tow section one for amp ads and one for mobile ads -> https://www.screencast.com/t/2Tz1ccuM3y1 here is an example -> https://www.screencast.com/t/JFFiV6li3ofE
-> https://www.ampproject.org/docs/reference/components/amp-auto-ads
