hi please help any one my social plugin social counter not working i have filled all details still? any one please tell me what can i do http://devilishlydeliciousfood.com see at the bottom , please kindly let me know what to do
Regards,
Ragz
Hello ragz,
Ensure that you are using the right version of Visual Composer which come bundled with the theme packet if you want to bring the best result. Try to disable the plugin and enable again from here -> https://www.screencast.com/t/OplzbBpfV0S Clear all your caches, purge CDN files and check the results.
