Hi all, I would appreciate any help as I can’t seem to figure this out.
Basically I just want my black menu bar and the white row underneath to be the same length. As you can see from where I’ve circled, the black menu/header is currently shorter.
Is there a way to stretch the header menu to reach the row below? OR is there a way to shorten the row below it to match? Thanks
Sorry image didn’t seem to work – here it is https://imgur.com/a/iEN1gSa
Please check this topic https://forum.tagdiv.com/topic/trouble-centering-cloud-header/
