need help to add my pinterest board within text of element box. I
I need help to add my pinterest board information within text of element box.I followed steps closely, as I interpret. My pinterest board not visible. I am using the fashion demo of News Paper 8.
  • This topic was modified 8 years by kerone.
Please provide more details to haw you are implementing a pinterest board. Is it a plugin? is it a custom implementation? Does the same implementation work on a wp default theme?
On the home page using the pinterest insert box from the WP Bakery Page Builder. I drag and drop to side bar on the home page. It reads like this. I copied and paste it below.
pinterest_id/board_name
Enter the pinterest board ID as it appears after the pinterest.com url ( ex. http://www.pinterest.com/ username/board and your board id will be username/board )
I enter this: https://www.pinterest.com/naturalhairblog/natural-hair-care-and-hairstyles-group/
It does note generate my pinterest board. I even tried https://www.pinterest.com/naturalhairblog/11111111111 with my board ID number as an example, after my username (naturalhairblog). It still does not show board visible. Just error on homepage.
Pinterest header
Same thing..does not work after I reenter my Pinterest board url as before, noted in the above feed.
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
Hallo, I have the same problem.
Can I also contact you?
Thank you;)
Note, this board throws an error, so it obviously will not work ….
Whoops! We couldn’t find that page.
How about these instead?
Remember you need to actually make the Pinterest board first; theme can’t make the Pinterest board for you.
I have a Pinterest board. Just need help to allow the board to show. I can get my Pinterest board code, but the pinterest block will not show it either. So I copied and pasted my Pinterest board url noted above
Based on the directions, unless I am following it wrong
Yes. You can contact..
Replied via email!
Having the same issue here. Can you post the fix or should I email>
@vrtech It should work if you configure it properly. Example
https://www.screencast.com/t/rq6NSsoN
Try fiddling with the widget settings, change the settings in it, the board should appear.
Hey there – did you ever this to work? I’ve tried Simion’s fix and changing the settings didn’t work.
Maybe the information you enter is not valid, I have tried again
https://www.screencast.com/t/bQxIheDM
Initially there were no images pulled, but after changing then number of columns a few times and waiting a bit, the images were displayed. This widget is not so reliable it seems, but it should work eventually.
Viewing 18 posts - 1 through 18 (of 18 total)
