Need help to create VIdeo Post
Hi Guys,
I would like to create slide for video like yours demo:
http://demo.tagdiv.com/newspaper/
And list video post like this:
http://demo.tagdiv.com/newspaper/category/video/
I create video post by add youtube link:
http://tinnongonline.net/?cat=14
But from homepage (http://tinnongonline.net), in “VIDEO HÀI HƯỚC” category, no thumbnail is display. In addition, it also create blank image in image slide bar on Homepage.
Please help me to create like what you demo.
Thanks for excellent theme.
Kindly regard,
Alex
I believe you refer to this slide: http://screencast.com/t/weVGusai You can add this to your sidebar from appearance > widgets, just add the slide widget to the sidebar you want, like this: http://screencast.com/t/8PA6o8djlHv
For a list like this you need to go to theme panel > categories, then select the category you want to customize and set the layout to module 6, like this: http://screencast.com/t/DcbxIJ5R31
Please make sure you add the video link and set the post right, like this: http://screencast.com/t/c58uQDv4WrA
You should also consider regenerating thumbnails: https://forum.tagdiv.com/how-to-fix-strange-thumbnails/
I could create it now. Thank you so much for your support
Alex
Hi Lucian,
How to create dropdown menu with image/video list like “Lifestyle” and “Video” menu in http://demo.tagdiv.com/newspaper/?
Alex
That feature is called a mega menu, you can read here how you can set and use it: https://forum.tagdiv.com/how-to-use-the-megamenu/
  • This reply was modified 11 years by Lucian.
