Need Help to Customize 404 Error Page
Well, I have successfully edited the 404 error for now. But I want to change the address title which comes in the browser’s tab from “page not found- TECH LEGENDS” to something else. Here’s the screenshot for better understanding I have marked the title in red http://www.screencast.com/t/xiaiOgcG
And another thing which I am curious to know, whether I can delete the header and footer completely from the 404 error page and display like : http://www.screencast.com/t/swkX1HdeyvQg
You can control this using a plugin like SEO by Yoast – http://screencast.com/t/nIFtkthjU
You can try to change the 404 template and remove header and footer, please make a backup of your 404.php file and use this content – http://pastebin.com/6iN1xk86 and it should work.
Well, the title worked by using SEO plugin. But the one you sent via pastebin didn’t work. It just came blank with the title only check that here: http://www.screencast.com/t/oBouK8tYq4H
I have checked again that code and it works fine as you can see – http://screencast.com/t/Kl8E10TwPH it should work also in your case.
Well, I replaced the original code and pasted your code without even touching it and updated in the 404 php file field still blank page is coming. I don’t know why. Anyways thanks for your help. I am happy with the current customization.
