Need help to fix a problem in header mega menu
Why is this submenu item name showing over as a heading on the drop-down mega menu?
My site’s mega menu shows a submenu item’ name as heading over dropdown mega menus. I dont want that text (OFFICER CADET) as a header on that drop-down mega menu. How can I fix it? Please help.
I believe the issue may be with the mega menu structure. Please refer to this guide for assistance: https://forum.tagdiv.com/mega-menu/
If you have a parent category with subcategories https://i.imgur.com/ScOzLD5.png -> https://i.imgur.com/9F8KosV.png, please ensure that you only select the parent category for the mega menu.
Additionally, kindly provide some screenshots of your menu settings and structure.
