Hello, thanks to provide me very good themes, however, might I be able to insert contact form shortcode in single post? I’ve already search for Newspaper hooks but not luck, I haven’t found anything about it
My newspaper site only build homepage with Tagdiv, the rest use gutenberg only. Please give me instruction how to do it
My website Url is https://reti.vn
For contact form, we recommend using Contact Form 7.
I try to help you with some screenshots because is easier to understand.
After you install the plugin go back on your WP Dashboard click on Contact > Contact Forms and copy the code under Shortcode https://www.screencast.com/t/NngJWh1j after that click on pages or in posts -> hover the page you have for contact and select edit with td Composer ( https://www.screencast.com/t/sqDfb18UaqP ) or you can click on the page and after is open click the button TAGDIV Composer ( https://www.screencast.com/t/4iZR8xcZb5 ).
After TD Composer is open click on add element ( https://www.screencast.com/t/rHVSES71x ), click on the row and drag it at the bottom of your page (or where you like to be your contact https://www.screencast.com/t/pPYxfNGA) and drop the row there, then search for column text then drag it and drop him on the row ( https://www.screencast.com/t/YCmZGKn5Qwn ) click on it and then in the sidebar from the left click on edit Content ( https://www.screencast.com/t/75fZTYkFoy ) then paste the code there and click on save and view page ( https://www.screencast.com/t/iT5Ex0ytiu ).
See the results: https://www.screencast.com/t/fDx1SAu6
Here is some documentation: https://contactform7.com/getting-started-with-contact-form-7/
I hope this will help you.
