Hello.. I’m facing some problems with my header. I would like to set up that header as same as another website using the same newspaper theme. I’m unable to setup that without getting help from someone.I want private assistance for this…
Here’s my site url: My Site
I want to make my sites header as same as : This site’s header..
You can import this header template https://cloud.tagdiv.com/#/single/header/Headers/700 and after delete with right click the elements that you don’t want from it https://forum.tagdiv.com/header-manager/
You need to change the logo for each viewport. Please check this video -> https://www.youtube.com/watch?v=HXQQygkCCJo and guide -> https://forum.tagdiv.com/add-logo-newspaper/
Will you help me setting up my site’s home page as same as this sites? Actually I like their setup. I’ll edit it later if it needs any changes. But initially, I would like to get a look like this in my site.
Hi Jabed, we can help you with indications for how to achieve that layout, but we, the support team can not set it up (Support Policy).
If you want one of our designed to do it for you, then you’ll need to make a request to custom work. For this you can use this link – https://tagdiv.com/submit-a-request/
Good to see someone new. I thought that girl(Anamaria) is the only one who replies all the users🤦‍♂️
Well I need indications then :’) BTW, u mentioned I need to make a request for custom work to tagdiv through that link. Could you please tell me if custom work is free to get or paid?
Hi Jabed,
You mentioned above that you’ll need help to set up the site to have a similar design as the one provided as example. So if you want us to do it for you, then is not covered by the support theme.
The custom work (as it’s sounds) is a paid services for custom request and those are preformed by developers and designer.
Now in case that you want us to help you with indications for how to achieve that layout, then the first thing will be to check how tagDiv Composer (theme builder) can be used, because all the changes will be make with it.
Also, here is a video tutorial – https://www.youtube.com/watch?v=SoGQ0d5kIBg
