Need help to stick article to the top of the homepage
I have an article that I want to stick to the top of my homepage. I tried clicking “Stick to the top of the blog” but that doesn’t make it appear at the top of the homepage. Help!! It is an important article and needs to be top and center. Thanks!
You need to set the post id in the filter tab to have a post sticky all the time on that block -> https://i.imgur.com/3uVxMOD.png
