Need help with a few things
Greetings
My name is Marko and recently i have been learning how to create sites using wordpress. I really liked the newsmag theme so I bought it. Before creating my real site I am trying to learn the theme by creating a fake “tech blog” with just few fake articles so I know how it all works.
So the site is here: http://www.techvitae.com/
I have a few problems, It seems like the changes that I make just dont work, I want for the first articles be listed in grid 4 with grid 6 – simple colors, It says that in categories menu and it saved, but it just doesnt change. Also i want the Articles to be listed in M10 view type, but it also doesnt change.
Also I can find a way to remove the “Accessories” thing and the “windows phone” on the side.
Also I dont know what created that grid on the bottom, and how to edit it.
That you!
Also I have a problem with the pictures that I upload, they are never as sharp as their stock photos, but they are normal resolution and sharp on my laptop.
bump help please
Sorry for the late reply but we answer from oldest topics to newest and because you updated your topic it appear to as among the first topics.
For a beater understanding of how theme features works please check our documentation: https://forum.tagdiv.com/newsmag-documentation/
Basically you can edit a page using Visual Composer page-builder: https://forum.tagdiv.com/newsmag-homepage-how-to-build-and-set-it/
If you’re referring at categories pages they can be customized from theme panel > categories section. The changes form that section will be applied only for category pages: http://screencast.com/t/hQa2OjRlpKK – http://screencast.com/t/kGHjRhqxWI3F
I am not very sure at what you’re referring in your second topic so please provide more specific details so I can get back to you with a more accurate answer.
Greetings,
Pictures will explain it better,
I cant find a way to remove these: http://imgur.com/Xps0No7
Also why does this look like that:http://imgur.com/IBOj8Bn
When i set it to this: http://imgur.com/G49hG0M
thank you!
These: http://imgur.com/Xps0No7 are block’s titles and can be removed from Visual Composer, just edit the block and delete its tite: http://screencast.com/t/c6n7YPAxM9pK
The options from this screen http://imgur.com/G49hG0M refers at categorizes pages, for example this one: http://www.techvitae.com/category/uncategorized/ In this screen http://imgur.com/IBOj8Bn you’re on a static page, not a category page. Static pages can be customized using Visual Composer page-builder: http://screencast.com/t/XoLoKDGlp
Thank you a lot!
