Need Help with Body layout
I changed the background color from Theme Panel and then the layout of my blog changes. It now looks like a boxed layout. Check here: http://www.techremark.com/2015/09/27/new-nexus-6p-press-images-leaked-884
Can you please tell me how i can change it to full width?
Unfortunately when background color/image is set, the site will automatically switch to boxed version. You will need custom modifications for this and I suggest to hire a freelancer to do this for you as we cannot provide custom work, sorry!
Here you can find an example how this can be done via custom css – https://forum.tagdiv.com/topic/cant-create-fake-full-width-top-menus-by-coloring-the-outer-wrappers-in-6-1/#post-56800
Can I revert back to default setting and get the normal look back? If so, can you tell me how because I don’t remember what the default color was.
You can reset the background color or any other color from the theme panel when clicking the clear button: http://screencast.com/t/0b7CzbdW
This will revert the setting to the theme default color.
