I need help with the header of block 21.
I wrote the following CSS code to change the header style for block 21.
.td_block_21 .block-title span {
background-color: #f1f1f1;
text-decoration: none;
color: #ffffff;
However, there is a line that displays and I cannot edit the line with the css. I’m currently using the Block header 1-Default.
The page I need help with is https://abeidblogs.com/
Also can you please write a CSS code to not to display category for block 21. Thanks.
If you want to change the color for some blocks all you need to do is to edit that page with tagDiv Composer, click on the block that you want to change the header color -> https://www.screencast.com/t/s8cYEYmv
IN order to hide the category tag on modules please check our documentation -> https://forum.tagdiv.com/category-tag-on-modulesblocks/
