Hi TagDiv Team,
Thanks for the recent update and for the hardwork and love you give to the Newspaper theme! I recently extended my support and hope you can help me with my simple problem.
I have added this CSS code in the Custom Code in the Theme Panel:
.td-post-content a:link {
border-bottom: 1px solid #05386b;
padding-bottom: 1.5px;
text-decoration: none !important;
color: #05386b;
.td-post-content a:hover {
background: #3da559;
I wanted to have vertical lines on each link on my website. But now, even the img tags are getting the border-bottom which doesn’t look nice on mobile.
Could you please help me solve this and know what’s the proper CSS so that the img tags don’t have the border-bottom?
Please try this custom css -> http://prntscr.com/opvsoj
.single .td-pb-span8 .td-post-content p a:link {
color: #05386b;
.single .td-pb-span8 .td-post-content p a:hover {
If this is not working properly, please provide me a link to one of your post, in this way I will be able to provide you the right custom css.
Hi Calin,
It worked on the Desktop version of the site and it did NOT work as expected on the mobile version.
Here’s a sample: https://prnt.sc/oq6c6t
And a sample post: https://nurseslabs.com/nurse-salary/
The line is being applied below the images.
Is there a more specific custom CSS for mobile?
Please remove all the css style that you add and set this one in Theme penal>Custom code>Advance css
color: #05386b;
http://prntscr.com/oqehic
And this one in phone section
.single .td-post-content p a:link {
color: #05386b;
http://prntscr.com/oqehyl
Also please clear all the cache after you save this code in theme panel.
Let me know the results!
If you are using the MOBILE THEME+AMP set the code for phone section in Theme panel> Mobile theme> Custom code > Css -> http://prntscr.com/orh8jo this should work.
