Hi! I can’t found where this css styles are from
https://prnt.sc/o2hqch
Problem is that we use Helvetica at theme panel and I can’t found where this styles with Fira Sans are from.
We use WP Bakery composer in our posts.
Hello !
We do not recommend using WP Bakery in posts. That issue can be caused by WP Bakery, you can use a single post template from the cloud library. https://tagdiv.com/cloud-library-page-templates-newspaper-theme/ and you can edit it using the tagDiv Composer.
Hope this was helpful !
Vlad, Thank you!
