Need help with custom CSS for submenu
I need the dropdown submenu (Recipes)(http://survivingfood.com/images/dropdown-menu.PNG) color to be the same color (dark grey) as the main menu with white text. I would like the hover background color to be the same grey and the text green on the hover like the main menu. I would like to accomplish this with the mega-menus staying the same as they currently are. (Current)(http://survivingfood.com/images/mega-menu.PNG)
The main blog url is http://survivingfood.com/blog
I am fully aware of that this needs to be done with Custom CSS but I have spent alot of time on it and I can’t seem to get it.
Any help would be greatly appreciated.
Thanks,
Maurice
  • This topic was modified 11 years by mauricem.
Okay I figured out most of what I wanted to do but when I try to change the background for the mega_menu it changes the background for the dropdown menu under recipes. If there anyway to change the mega_menu menu background without changing the recipes dropdown menu background>?
Hi mauricem,
I’ve checked your site and I understand which is your desire. Unfortunately, it is not a simply task to achieve this and it required custom work. To display more levels you need custom modifications and I suggest to hire a freelancer to do this for you as we cannot provide custom work at this time, sorry.
Thank your for your understanding!
