Hello, team tagDiv.
I am using flex block 1 to create a module similar to block 19. For this, I decreased the image width and then changed the layout to float left so that the meta info can float to the left of the image and then provided some padding. The problem is, it looks fine on the desktop but not the mobile phone. So I want to display excerpts on the desktop and hide them on the mobile phone. Is it possible? If no, any alternative?
Hope you reply,
Have a nice day.
Pratiek.
Using flex block you can set different layout for each device.
https://www.screencast.com/t/XOAd5h98c
https://www.screencast.com/t/Ekz86CCNJ
Hope this will help you.
