Need help with horizontal module divider.
I am trying to create the divider like this.
https://imgur.com/a/xgAM1PM
How do I do that.
Regards,
Hello !
That layout comes from the a BLOCK that is a element of TagDiv Composer. You can achieve that by adding a similar block using the tagDiv Composer.
Hi Vlad,
I have tried multiple blocks. Flex block, regular block. Could you please help walk me through this?
Thank you
Hello !
As you can see here I have added a Block 16, set the excerpt length to 1 and add some custom css code as you can see here: https://www.screencast.com/t/o9NKz9Ni ; https://www.screencast.com/t/8TLt78rc
.td-block-span4 .td-module-meta-info {
display: none
The code must be inserted here: https://www.screencast.com/t/J1Nxw5s5
Thank you for quick respond. However, I’d like this vertical line in the red rectangle.
https://imgur.com/a/u4k9Idn
I should have explained it more. Apologize on that.
Hello !
Unfortunately the separator cannot be done. I am sorry for the inconvenience !
Thank you for your understanding !
I see. Would it be possible to request this for the future update? This feature would be very useful.
Thank you
Hello !
I will pass this information to our developers and maybe there will be implemented in the future !
