Hi there,
I purchased Newspaper theme and I am really satisfied. I have some problems so I would like to know if anyone had the same issues. My problems are mainly with images. My website is dzezar.com.
1. I use Big Grid Slide in homepage. The images are shown, but the slider is not working. I set it to 2 seconds and limit 10 posts. Also, I did choose proper category that contains more than 100 posts.
2. Sticky menu is not working.
3. Banner in sidebar is good only in homepage, but in post there is missing photo – photo is not loaded (but the link is working).
4. When I turn on Image loading – animations (LazyLoad) all images from the entire website disappear (from all posts and categories). When I turn it off everything becomes normal.
5. I add new post, and I choose Post template Style 7. No image. You can see that here: http://dzezar.com/skandalozno-turska-sahranjuje-puciste-na-groblju-izdajnika/
Hope that you can help to solve my problems.
Hello p0ltergeist,
1)Ensure that you have right set your Big Grid from Block Settings in order to achieve best results. Check this screenshot -> http://screencast.com/t/57E4NmtR
2,3)Try to read all our documentation regarding on Sticky Menu and ensure if you have followed these steps in order to achieve as you wish. If your problem is still there after this, please try to disable all the active plugins, leave just Visual Composer to active and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
4)Here is talking about some .js errors which occur due your untested plugins used by you and which interfere with the theme code or with other plugins and cause this issue.
5)This happens due your untested plugins. Try to disable all of them and use the theme only with the required plugins which come bundled with the theme.
The only plugins that I have installed are Disqus comment system, Nextgen gallery and Contact Form 7. I had the same problems before I have installed any of these plugins.
1) I did set 10 posts as I mentioned above, just like in your screenshot.
2) I did read all documentation more than once.
I don`t know what else to try.
Hello p0ltergeist,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer. Also, you can provide the link of this topic so we can easily identify you.
