For some reason there’s a large amount of padding / empty space after the title in the “recent entry” module / block in the sidebar. Where can I adjust this, or what CSS can I add to modify it? Please see this link for the screenshot: https://imgur.com/AgARxrY
The URL is https://www.unemployal.com. If you scroll down, the issue occurs in the individual entry blocks underneath “Past stories” and when you’re in an entry, the issue is in the entry blocks in the sidebar to the right.
I provided the screenshot in the original post. You can see it on the side bar when you click on any of the articles.
Hello unemployal,
I have inspected your page and it seems to be a little strange with your block 5 on the sidebar. Also, if you are using some untested plugins, try to disable all of them, leave just to active only the plugins that come bundled with the theme core files and check the results. Clear all the caches and check the results.
Another quick solution for you would be to use the code below and place it in Theme panel -> Custom CSS area.
.td-newsmag-voice .td_module_3 {
height: auto;
The result is here -> https://www.screencast.com/t/orvC4ipZrQJy
