Need help with Romania News PRO header
Hi, I can’t find the option to change the header background photo, can you help me please?
I tried to edit the main website and the cloud template, but when I select the “zone” I can’t find the option to change it.
Website: https://nortebonaerense.mineolo.com/
Screenshot: https://prnt.sc/16xx83v
To change the background image, you need to select the row on the header menu element, and the tab CSS you can remove/change the image => https://www.screencast.com/t/ciUKXdLTWi -> https://www.screencast.com/t/7Oxv2GfK
Hope this helps you!
Muchas gracias!
