Need Help With Stubborn Error [wp_booster….
Hello Emil,
I have spent hours trying to troubleshoot and fix this.
Here is the error code:
Catchable fatal error: Object of class stdClass could not be converted to string in /home/content/77/11795277/html/wp-content/themes/Newsmag/includes/wp_booster/td_block.php on line 131
#1 Only occurs on posts and pages (not home page)
#2 Removes many images, eliminates 90% sidebar and 100% footer
What I have done:
#1 Clear Cache
#2 Inactivate all plugins – Reactivated and it worked briefly and the error came back.
#3 Did an FTP install of theme and Visual Creator (Now version 4.74)
#4 I tried backing up to my last Updraft back-up (October 6th)
It is very stubborn for a n00b like myself; perhaps an expert can pinpoint what’s triggering this.
Here is someone else you helped with the exact same problem (exact location, exact line 131):
https://forum.tagdiv.com/topic/change-widget-text-background-color-catchable-fatal-error/
Thank you sir.
-Jared
Is email better?
Alin replied you via email!
Hi Andrei,
Alin emailed me approximately 3 hours ago and I replied with the log in (admin) for my site.
I haven’t heard back.
Thank you (was emailed to “contact(@)tagdiv.com”
Oh….I saw your support hours. So it was 2 hours before 17:00 (GMT +2) when I emailed admin access to my site.
We have lots of messages and the response order is from older to newest. We will get back to you as soon as possible.
Thanks for understanding!
Hi I am getting the following error on Category pages and also when the site is searched using the search module.
wp booster error:
Missing module: td_module_search
/nas/wp/www/cluster-41040/luxniseko/wp-content/themes/Newspaper/loop.php
When I installed the theme I deleted the old plugin and added the new one. Everything else works splendidly.
Please advise how to correct the problem
Best Regards
Del
already try and follow all suggestion here
already delete the trouble maker wp booster
all my system status are green
but still error only in this category http://www.pejawan.com/category/teknologi/
really2 need help here 🙁
im desperate
Hi @cocoroyce
Please check this topic, I have posted a solution here: https://forum.tagdiv.com/topic/wp-booster-error-6/#post-62185
@goeske77
Emil replied you via email.
