Hi all. I’m having a little trouble with the [tagDiv] Image box
The [tagDiv] Image box on the main page has settings that allow you to adjust the distance between pictures.
I wanted to put [tagDiv] Image box in the sidebar as a widget, but unfortunately there is no such setting for it. How can I change the image spacing of [tagDiv] Image box in the sidebar?
If you use a cloud template, then you can have more settings for the customization and pretty easy to use via TagDiv Composer.
You can add the sidebar in the tagdiv Composer. Steps:
1. Add 1 row (or existing one)
2. Split into 2 columns( 2/3 + 1/3 )
3. You can add whatever element you want into the second column and consider it a sidebar.
I already added a [tagDiv] Image box to the sidebar. The problem is that there is no “Gap” option in the settings of this element for the sidebar.
I don’t know how to adjust the distance between [tagDiv] Image box elements in the sidebar. Maybe I need to add something to the CSS?
Create the sidebar with the TagDiv Composer, add the element there and set the gap like in this video: https://www.screencast.com/t/pj04gr5GPobl
I want to put the [tagDiv] Image box exactly in the sidebar in the Widgets section. This is so that [tagDiv] Image box will be displayed not only on the main page but also in all posts.
But when you add [tagDiv] Image box to the widget, the gap setting is missing.
