Hello
https://recipes-for-you.com/
1. how to remove the display of the author and date on the post preview in need help with ?
2. increase the height of the selected blocks (make the block height 250 px) and make the distance between them 2 px
highlighted the blocks in red
1. If you using the Flex Block or Big Grid Flex in the layout are the options “Show author”, “Show date” and you can choose to hide => https://www.screencast.com/t/6UPXQbiTO2
For mobile theme version to remove the author name on the blocks, please go in Theme Panel -> Block Settings -> Meta Info on modules/blocks and disable the author => https://www.screencast.com/t/5w5CxkcU
2. You can’t change the layout and customize the mobile theme version. There are some settings in the Theme panel -> Mobile Theme and Dashboard -> AMP only.
we use plugin tagDiv Mobile Theme – https://prnt.sc/W3IfDFxg2pZ4
For a mobile theme, you can’t increase the height of modules/blocks or change some things, this is made custom.
For the informations that are displayed on the blocks, you can change them in Theme Panel -> Block Settings -> Meta Info on modules/blocks and disable the author => https://www.screencast.com/t/5w5CxkcU
