Need help with the reviews
Hello
I don’t have any coding experience and am trying to setup the site. While there are multiple other areas, can I please get an answer for the below?
Reviews
1. Can I get the ratings displayed at the beginning of the post just below the title?
2. Can I get the Summary / Verdict displayed below the ratings as requested above?
3. Can I get a Pros and Cons table setup below the Summary? Sample : http://www.techradar.com/reviews/wearables/apple-watch-2-1323213/review
Unfortunately if there is no setting for your preference it has to be done through coding. It;s true wordpress and themes do not require coding skills but this is available if you only use the theme and wordpress settings. If you plan to move things around you should be aware that in almost all cases this requires coding.
1. The ratings are added at the bottom of the posts on each post template in particualar. Here is where the code is found: http://screencast.com/t/L6XqhzRkG
2. The summary will automatically display below the title as the rest of the reviews if you do the customization properly: http://screencast.com/t/6p3Fs1Fq
3. You can write pro’s and cons in the description filed below the review. Here it is on the back-end: http://screencast.com/t/XmbCPOmJZs
