Need help with thumbs and partition of homepage
https://arildkrovoll.no/
As you see, my featured image (to the left) are unsharp — help
I want to be a bit largerm about size as them to the right
Next
I want my left column divided in two.
The top 10 “siste artikler” (latest post) as is today
All the lower “memories” (articles I write today about montain trips long time ago)
For more customization, I recommend you to edit the page with the TagDiv Composer and add a flex block instead the default block that you use: https://forum.tagdiv.com/flex-block-settings-guide/ With a flex block 1 for example, you have the possibility to make the featured images like a square for example from their settings.
Also, you can add a row divided in as many columns you need( https://prnt.sc/-SAV6yHpckUp), but only if you use the TagDiv Composer on a cloud template. Take a look here in this video for example where I build 6 columns: https://www.screencast.com/t/mZ2c5XamTFN
Please dont recom TagDiv
THIS is a non pro hobby of mine, its bare keeping up as is
Tryed TagDiv last summer
My website crashed and went off line for weeks, I was unable to fix it.
So I need a old fashin html
or a new theme supplier.
I’m sorry about this, but we can try to help and recover your website as soon as you make a full backup before.
The default version of the theme has not so many options for customization to achieve what you need.
