No matter what I put on the Shop page, nothing displays. I added woocommerce blocks with visual composer, but they didn’t show when I viewed the page. There’s a default display with 4 products and a sidebar. So then I copied this demo http://pastebin.com/hxJ8ENx1 and put it in, but it still just displays the default 4 products. I can’t get anything to change or display on the shop page other than the default 4 products with pagination and sidebar. (I don’t want the sidebar on this page).
It sounds to me like you are editing another page and not the shop page that is used in woocommerce. I’ve been there as well:). Please do not create a page named “shop” as woocommerce already creates one by default. Please try to change the shop page from the default one in the woocommerce plugin.
For some strange reason I can’t figure out, it will not work. I have the shop page (editor shows no content). It shows 4 products (and sidebar). So I made a new page called store and copied the code from your demo in it. Nothing shows up except those 4 products. It’s like it’s not paying attention to what’s the the content area of the page editor at all. Completely ignoring it. The shop page is here (empty content): http://dumpdonaldtrump.net/shop/ The store page I made using what I copied from your demo page is here: http://dumpdonaldtrump.net/store/
It’s not displaying what’s in the content area of the editor.
You will have to specify in the woocommerce plugin settings which page you want to use as a shop: https://docs.woocommerce.com/document/woocommerce-pages/
i did that. It won’t display anything I put in the text editor. I copied your VC example, but nothing shows (not categories, not the shop banner, not “display 12 products”, etc)
Ok Please disable all plugins except visual composer and woocommerce, clear cache and reset cdn files to make sure plugins do not interfere with the woocommerce plugin.
If you still cannot get the plugin to work properly, please contact us via our email address at contact@tagdiv.com and provide wp-admin so we can login and investigate
