I’m sorry, but I’m not sure I fully understand what you are trying to achieve.
If you want to have the author on the blocks, please edit with tagDiv Composer, select the block and in the tab called “Layout” is the option to show the author -> https://i.imgur.com/3Zo0njy.png
Please check
Icons are missing. Newspaper icons I guess. Neeed a fix
Please provide the link to your website.
Also, please check if you have an error in the console as is described in this topic https://forum.tagdiv.com/topic/icons-not-displaying-2/
Hope this helps you!
Seems this issue is caused by a cache plugin -> https://i.imgur.com/ykoieqj.png
Did you use a plugin to minify the CSS/js?
Yes minify CSS and java through wp-rocket
This reply was modified 4 years by
iamratnesh.
How do I exclude that icons thing to not minify through wp rocket
Wait, is this issue related? Image
If so, then what should I do
iamratnesh.
Hello @iamratnesh!
We can take a look to see what happened there exactly.
– wp-admin URL and credentials
Our team will take a look!
