Need to understand difference between various Ad options
Hello Team,
Most of the Ad placing options are self explanatory. I had gone through your documentation and a small video for Ads but am not able to understand the use case of below –
Post Template style 1
Post Template style 11
Post Template style 12,13
Smart List 6,7,8
Custom Ad 1-5
Could you please help me in understanding the usecase or guide me to documentation or thread where it has already been discussed.
Ankur
Post template ads ->https://forum.tagdiv.com/post-template-ads/
This templates are space for the mode and plate were is showing the ads
The ads is showing in article below feature image
Is a special template for feature video, the ads appear as right sidebar
This post allow you to have a full width for ads
Smart List 6,7,8 are smart list special made for showing ads inside of them
https://www.screencast.com/t/vk13QErid
https://www.screencast.com/t/b3x6gLw7
With Custom Ad 1-5 you can add custom ads ( this fields permit you to have more ads to please in your content ).
https://www.screencast.com/t/E3Wlt1IpaGK0
Hope this will help you to understand better.
Thanks am clear with Custom Ad.
The Post template – does it mean these ad options are specific to the post template that I choose in post settings?
Smartlist – Am sorry, but I am unable to understand the concept of smartlist itself. Do you have any documentation or thread where I can gain more information.
Yes, you understand well the Post template ads https://www.screencast.com/t/3aAd5T8tK
The same is wit the smart list, those are the only smart list that can have attache/set ads.
So is there anyway I can place two inline ads in my post at two different places?
Regards
Ankur
Unfortunately you can add only one inline ad, but you can make some change in theme file to set that ad after each paragraph set in theme panel.
For ads after each paragraph set in theme panel on desktop please go in wp-content\themes\Newspaper\includes\wp_booster\td_module_single_base.php
https://www.screencast.com/t/RZMsKj6A
Hope this will help you.
hi, I cant find the file you mention.
Please help me, I want to display article inline ad after 0 paragraph.
thanks
Hello !
Sorry for missleading you !
Here is the correct path: https://www.screencast.com/t/tByKlSb7ON
wp-content\plugins\td-composer\legacy\common\wp_booster
