Good evening team ‘tagdiv’, how can i set this type of background (http://prntscr.com/adv5dd) in newspaper6 default demo (http://prntscr.com/adv609)
You can add an image on a row in visual composer like so: http://screencast.com/t/RzYGk3Dhvs
Then you need to assign an extra class to the row so you can target it with css: http://screencast.com/t/tw1jAKzptg4
And then you can apply a top padding to the content:
.myextraclass .wpb_column{
padding-top:60px;
result: http://screencast.com/t/dxzbFvOx3mq
Hope this helps.
Thanks for quick response. after your instruction the result is (http://prntscr.com/adwypp) not looking good.
how can i fix this issue ?
thanks.
That is because you have the website boxed. If you apply a background image or color (white counts too), the theme will make the weebsite boxed version. if you want to be able to have full width elements like the block you exemplified, you need to remove the background image and clear the background color: http://screencast.com/t/eRe8EtCO
