Need your help
Hi Catalin,
Is there a way to move those arrows from right to left?
  • This topic was modified 10 years by moor.
Hello moor,
I have checked your screenshots and I saw that you are using the RTL mode (probably your native language) and our theme has not been designed to be used in this way, sorry! Please notice that our theme has no support for this layout as you can see in our support policy here -> https://forum.tagdiv.com/support-policy-2/
Unfortunately, we have no plan on implementing it in the near future. Implementing RTL support in our theme will require 2 style.css files and it will add significant “weight” to the theme. Using the RTL mode means that lots of elements have to be adjusted and this thing involves custom work and we cannot provide this at the moment!
So, if you want to display more levels in our theme and you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
