Newpaper Theme will not activate
I purchased a new copy of this theme for my site and it will not activate either way, by form or manual. No plugins except tagDiv Composer was active. Documentation was followed and it will not activate although it says repeatedly is is. The system status says Its not registered. There is some code in a file somewhere blocking this. With all the complaints I’m reading from others, surely someone has a solution other than just follow the documentation for activation because it doesn’t work.
same problem, i have found
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
