Newsapaper 11 : Single Related Posts Block
Single related posts block is missing in TD Composer. But can be easily found in imported templates from Library.
Hello Amit!
Yes, it is true because the functionality from single related posts block was moved in the flex blocks. For example, add a flex block, go to the filter tab of the element’s settings and from the dropdown category filter you can choose between: Single – More from author, Single – Related by category, Single – Related from tags.
The original single related posts block is not available to be added in TagDiv Composer anymore.
