NEWSLATTER PROBLEM WITH MAILCHIMP CODE
When I add code from mailchimp to the newslatter plugin it doesn’t work?
In the newsletter provided by our theme, you can use embed code from Mailchimp, Mailer Lite or FeedBurner. https://forum.tagdiv.com/the-newsletter-plugin/
If you want to use another newsletter you can try to set the code in column text or text with title => https://www.screencast.com/t/N6rPZvAa The shortcode/code is automatically saved.
