Newsletter: Homepage problems switching languages
I am having problems switching languages.
My website http://www.tango21.info it has german as a main language, when I try to switch spanish it does not show the spanish homepage.
If I am logged in the website shows the two language options. Everything works well.
I attach two screenshots. Common unser not logged in cannot switch to spanish language in the Homepage.
http://tango21.info/wp-content/uploads/1-Tango21-not-logged-in.jpg
I am logged in, when I am in the german homepage and I want to switch the language to Spanish there is no problem
http://tango21.info/wp-content/uploads/2-logged-in.jpg
The spanish homepage url is: http://tango21.info/?lang=es
Whe I am logged in, the website works well and shows the right Spanish homepage.
http://tango21.info/wp-content/uploads/3-espanol.jpg
If I try to go straight to the Spanish homepage website, it shows page not found.
The homepage website works fine when I am logged in and didnt work as a common visitoir. Categories and other menu works ok.
I would really appreciate your help.
What plugin are you using to translate your pages ?
WPML is the plugin.
Hi GeertBoettger,
So if the problem appear only when you are not logged, most probably it is from cache, please make a test, disable all cache you are using and check to see if the problem is persisting.
Also it can be that you link to be hidden, for this, please check the steps from this topic https://wpml.org/forums/topic/translations-not-showing-unless-logged-in/
Let us know the results!
