Newsletter problem after update to Newsmag 4.4
Hi!,
just after the update to Newsmag 4.4 I have a problem with the column on the homepage.
Then I decided to delete the Newsletter plugin but… doesn’t work.
Problem to fix: image here
Any suggestion to solve it? Thanks!!
That seems to be the Newsletter shortcode. Delete the newsletter plugin from your plugins section, then install it from the theme plugins panel
https://www.screencast.com/t/xfOGzQN6
Then the newsletter should work properly.
Thanks Simion, it works! 😛
