NewsMag Security Issue… Help Me…
Here I have the main Security Issue, Please tagDiv Help Me to Fix This Issue.
SiteLock Showing this Suspicious Content Warning.
Category:Suspicious Content Status:active
Page URL: https://www.example.com/wp-content/themes/Newsmag/js/td_site.min.js?ver=1.5
Note Info: External iframes found : about:blank found on sample pages ( https://www.example.com/wp-content/themes/Newsmag/js/td_site.min.js?ver=1.5 )
Description: We have detected iframes to external urls on your site. While there are legitimate uses for this, it is also commonly used by hackers to insert content into your page. We recommend you check the urls in this iframe and make sure they are a trusted source.
Action: Check the url to make sure it is something you recognize and are ok with some of your traffic being sent there. If you do not recognize it, remove the iframes and links throughout your website.
  • This topic was modified 10 years by K.H.R.
Those target blanks come form theme’s modal/light-box view feature script and they indicate a false positive so you don’t need to worry about it.
