Newsmag system status/Speed Booster issue?
Since a recent Newsmag update the Speed Booster in Newsmag system status seems to conflict with all other plugins.
I thought it was just one, but every time I remove a plugin the next one is named as the problem.
It says this in the Newsmag system status:-
Speed Booster – v4.1 – Disabled – incompatible plugin detected: ewww-image-optimizer/ewww-image-optimizer.php
But if I disable ewww-image-optimizer the next plugin is named.
Anyway – even if it solved the issue, I need my plugins!
Any ideas how to fix this?
You need to delete or comment out this code in the td-speed-booster.php:
http://screencast.com/t/HaOmyxJ45oX
I followed your instructions, and the speed booster did change to Active, but when I took a look at my Woocommerce products it made all the 3 columns change to 2 columns, and the Woocommerce product images went full page width size. So I had change it back again?!
Try to comment this line from td-speed-booster.php file: http://screencast.com/t/cHRjk591m It should work fine: http://screencast.com/t/OcfsAlTE
Let me know how it goes!
  • This reply was modified 11 years by Andrei L..
