Newspaper 11 – I moved hosts for the same domain name. tworoadslifecoaching.com
I moved from dreamhost to hostinger with the same domain name.
I used WP migration to move the site.
Now on the new host with the same domain. The theme shows registered but under license it says no domains associated with your license key.
Now the site is not working.
Please let me know if you use a child theme, if yes, please use the main theme.
Also, please try to reset the key and activate again the website -> https://i.imgur.com/6MOhNZo.png and check after the license.
